fan switch
Old Aug 3, 2003 | 11:14 PM
plowboy's Avatar
Default fan switch
does anyone know how to rig a toggle switch up to the fan on a 2001 sportsman 500 so that you have auto and manual on the fan? i have been having problems with mine overheating. i dont think the fan is kicking on as much as it shouldbecause it dont overheat all the time. thanks for any help.
Old Aug 4, 2003 | 12:38 AM
JWtrailblazer250's Avatar
Default fan switch
I took out the auto switch on my 300 xpress and just wired it together to where it runs when I turn the key on cause the switch keep going out on it.Works fine now.
Old Aug 4, 2003 | 12:40 AM
Sniclefritz4's Avatar
Default fan switch
one of those would be nice on a pred too!!
Old Aug 4, 2003 | 01:14 AM
Jeepman1991's Avatar
Default fan switch
Make sure your radiator isn't full of mud, dead bugs etc.
Take it off and clean it.
My Scrammy was overheating because of that.
Its worth a try.
Old Aug 4, 2003 | 11:22 AM
nez02's Avatar
Default fan switch
plowboy, My grandpa was having the same problem in his 2000, 500 sportsman. He took it to the shop and alls they did was add more radiator fluid because even though it was at the full line on the tank, it wasn't enough to trip the sensor. Add a little more fluid and see what happens. Hope i helped
Old Aug 4, 2003 | 08:49 PM
plowboy's Avatar
Default fan switch
thanks for the help. i have took the rad out and cleaned it and bled all the air out of the rad several times. by running the fan all the time couldnt that burn up the fan motor. this is a problem that i havee been fighting for several months and every time i thaink ive got it fixed it starts overheating again.
Old Aug 5, 2003 | 12:23 AM
Default fan switch
Mine hasnt burned up at all,still has the stock one on it!
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
