Need help with scrambler
Old Aug 14, 2003 | 12:54 AM
savage21's Avatar
Default Need help with scrambler
NAW IT AINT SHEERED AT THE ENDS ,THANKS FOR THE HELP DO YOU HAVE ANY OTHER IDEAS WHAT IT COULD BE?
Old Aug 14, 2003 | 01:18 AM
savage21's Avatar
HEY IF ANYONE WANTS TO HELP ME MY IM IS MIKE128190 MY E-MAIL IS MIKE128190@AOL.COM
Old Aug 14, 2003 | 06:25 AM
Alpine2's Avatar
I know you need help but I am having a hard time trying to invision your problem . does the throttle buy loose mean it is spinning on the hanlde bar or is the thumb leveler wiggling or does the thumb lever feel like there is nothing there buy that I mean does it push in real easy sloppy like.
If it is wiggling (Thumb lever ) try tighting the bottom nut on the lever .
If it feels like there is nothing there (Sloopy real easy to push in) sounds like a cable problem might have replace it or the spring in your carb is jammed up compressed from puching throttle trying to do wheelies or it is busted
These are the only things I can think off off the top of my head. Good luck
Old Aug 14, 2003 | 09:12 AM
sportkc's Avatar
Need More Info. I this a 400 or 500 Scrambler? If it is a 400 have you checked the cable at the oil pump. When they brake at the pump it can cause alot of play in the throttle. Kevin
Old Aug 14, 2003 | 12:58 PM
  #15
savage21's Avatar
what do i do to cdheck the spring in the carb. step by step, and how do i chekc the cable at the oil pump?
Old Aug 14, 2003 | 01:02 PM
  #16
savage21's Avatar
like the thumb thing doesn't go around in circle it just has lot of play be fore i can give it gas, i can give it gas and it will go wide open their is just alot of play in it , i can push the thumb lever like half way before anything happens, what should i look for step by step. what would be your next move
Old Aug 14, 2003 | 01:14 PM
  #17
MOJAVE02's Avatar
check the spring, i have never been inside the carb on a scrambler but i would assume it would be the same as most. just take the carb cap off and there should be a spring and then the needle assembly, check out the spring for any problems with it. also check the needle assembly and other components in the carb, something could be sticking.
Old Aug 14, 2003 | 01:56 PM
  #18
savage21's Avatar
i have pictures anyone who wants to give me a lil help im at mike128190
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
