Carb gettin no gas
Old May 28, 2000 | 10:30 PM
stevie's Avatar
What is the thing on the frame that goes to the carb it is up by the rad cap
Old May 28, 2000 | 10:57 PM
losi's Avatar
The thing by your radiator cap is a fuel pump that is vacuum operated by motor pulse. One thing you said about melting the vent hose for the tank, if you sealed it could cause a vacuum on the tank not allowing fuel to flow. Try to start it with the gas cap off and you will have to crank it a minute or two for the pump to get fuel to the carb. I am not familiar with the pump but it could need priming before it will start pumping.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
