ebs plastic nut?? where is it? 2001 500 w/ebs
Old Aug 21, 2003 | 12:13 AM
pol5002's Avatar
Default ebs plastic nut?? where is it? 2001 500 w/ebs
Where is this nut. I am losing top end and hear this might be a problem. Does my atv have this and where is it??
Thanks!!
Old Aug 21, 2003 | 10:38 AM
Moodster's Avatar
On the front clutch,it is made of a white plastic,also check belt deflection for a worn belt,that also can have an effect on top speed.
Old Aug 21, 2003 | 10:49 AM
pol5002's Avatar
I replaced the belt. No help. Is the nut behind the drive clutch cover? It is the only white piece I see. It has slots in it.
Old Aug 21, 2003 | 10:55 AM
Moodster's Avatar
Yes,it should be tight against the inside of the clutch.
Old Aug 21, 2003 | 04:35 PM
pol5002's Avatar
Can this be tightened with a normal wrench, and does the clutch cover have to be removed,
Thanks
Old Aug 21, 2003 | 07:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you refering to the plastic spacer on the center bolt? how many miles on the machine,and have you cleaned the clutches?[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 21, 2003 | 09:10 PM
pol5002's Avatar
I believe that it is the spacer. Where exactly is the nut? I have not cleaned the clutches. I checked the spring on the drive clutch, It looked O.K. Bike will run about 52 downhill and drops to 48 on slight uphill grade. It has very good acceleration. It just flattens out at that speed.
Old Aug 21, 2003 | 09:18 PM
pol5002's Avatar
1700 miles by the way
Old Aug 21, 2003 | 09:48 PM
pol5002's Avatar
I am not reffering to the plastic bushing that guides the long bolt. their is a white piece behind the spring. Don't have bike apart right now to tell exactly.
Old Aug 22, 2003 | 10:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
I know this might a stupid question, but what nut are you refering to? I can bury my speedo on my ho at 60 mph on a straight away. I've had both of my clucthes off and disassembled to clean the belt dust and mud out. on polaris,you need to keep your clutches fairly clean for top preformance. [img]i/expressions/face-icon-small-confused.gif[/img]
