stearing post
Old Aug 29, 2003 | 05:52 PM
scrambler420's Avatar
Default stearing post
hey guys just wondering if my post should be perfectly straight or not?mine has a slight arch to it.its not bent side to side,it arches towards the front of the machine.thanks for the help
Old Aug 30, 2003 | 10:41 AM
i need to order a new one if its bent,so come on guys respond please
Old Aug 30, 2003 | 11:44 AM
Sheilakiller's Avatar
I looked in my manual and it does'nt show or say anything about steering post arc so next thing to ask yourself is ,"does it effect my ability to avoid trees... if there is a slight problem...maybe don't sweat it but if you feel not good about it then by all means, change her up....not a quick job...my 2001 scram is about to be stripped of all skins today for I need to take motor out and check its insides...if I see anything arced, I'll be back to tell you.....Later
Old Aug 30, 2003 | 12:07 PM
sweet thanks a bunch..the handling of the machine has gone to $hit,ive just replaced the tie-rod ends inner and outter,a-arm bushings the ring and the bushing that slides into the arm,im waiting for a upper post bushing,the lower seems to be tight.while waiting for the upper bushing i noticed the arch in the post and was just wondering..i work in a sand and gravel pit and crashed pretty hard after jumping a huge pea stone pile,so im thinking it got bent..the headlight bracket is also bent the lights point off the the right..anyone use hotseat performance's stearing post?is it worth the money?thanks
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
rgjackson
Sep 23, 2015 01:53 PM
black_thunder
Sep 22, 2015 07:59 PM
