Problem with trail Boss tank leaking again
Old Sep 2, 2003 | 01:43 PM
BossMann's Avatar
Default Problem with trail Boss tank leaking again
Does everyone have a good rear brake pedal? If so will it lock the rear tires.Has anybody checked to see if their tranny is leaking also.
Old Sep 2, 2003 | 02:18 PM
DEPALMA's Avatar
i just thought that foot brake was make pratend. It never worked. Besides these stupid little things this is a easy to ride fun quad.
Old Sep 2, 2003 | 02:59 PM
markbanger's Avatar
IF YOUR FOOT BRAKE ISN'T WORKING YOU NEED NEW BRAKE PADS IN THE BACK YOUR FOOT BRAKE CONTROLS YOUR BACK BRAKES AND THE HAND CONTROLS YOUR FRONT AND BACK.
Old Sep 2, 2003 | 03:36 PM
Brushcrusher's Avatar
Had the same leak on my 700. The 2 aluminum nipples that thread into the bottom of the plastic tank leak. Drained tank removed nipples ,put some sealer on the threads,reassemble. No more leaks. BC
Old Sep 2, 2003 | 05:08 PM
  #15
BossMann's Avatar
The rear pads were shot & the dealership did give me a new set.The hour meter showed 7-hrs on it.The mechanic also said this would cure the problem( new rear pads).Well, still no pedal & limited using the hand brake.Tested it on jack stands.Rev up in gear & then hit the handle brake,this does not stop the rear axle in a timely mannor.Just wondering if it could be in the rear caliper.I feel it,s the rear master cylinder
ranvette
Jun 21, 2015 02:49 PM
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
