Help terrible sound coming from the rear end ??!!\
hit enter to fast again
Here is my problem
all day long I could heere something in the rear making a grinding or popping sound on hard acceleration or turning sharply and accelerating
The chain and sprokret look fine, maybe it is in the carrier, any ideas.....
02 500 scrammy 4x4
Here is my problem
02 500 scrammy 4x4
Put it up on jack stands and wiggle the rear axel. If it moves around them your bearings in the carrier are bad. I would also check to see if you have something stuck in your chain guide or if it needs to be adjusted. Do your lube your chain and grease your carrier regularly? I had clanking sound coming from mine. The chain looked OK but I replaced it anyways and that took care of the problem. I also added a chain tensionor. Did you check to see if your were missing any rollers on the chain???
Hi i had the same problem with my trail boss. The problem was the chain guide. To help the problem I lube a lot and I adjust the chain guide so the chain rests almost on the bottom of the guide so that with no one on the quad it grinds but when i sit on the quad the tension lifts the chain up off the guide a little. When I give it some gas the chain finally stops grinding the guide. ...I hope this helps
thanks for the replys
I had to go out of town on bussiness unexpectly so it will be the weekend before I can put what I have learned to the test
will keep you guys posted on what I find
joe dirt
joe dirt
toonces
Oct 16, 2019 12:11 PM
