Polaris high performance quad???
#44
Originally posted by: yoshimuraRS3
Stop over estimating your Predator.
400ex > Predator in technical rides. Thats it
#45
well first...that hill shows that the 400ex lacks some serious power stock....that banshee had some major work done to it...would u like me to post a vid of a modified scram flying up that same hill,...and catwalken on the way up?? lol, your lost buddy...face it, you probly dont even own a quad, just some punk 12yr who wishes he had a quad, and definatly lacks common sense/information to even post a respectible and constructive post....wouldnt it b amazing if he actually posted something constructive?¿ ya...i didnt think so......plus i think its juniors nap time, he is a little cranky....
plus i think juniors quote is a little off....i think he meant...
Must be something wrong with it cause I see every1's ***
when they pull away from him....
#46
Crash929: 1st of all, when i say that theres must be something wrong with it, im being sarcastic.
I raced against z400, raptor, banshee, yfz450, predator, well, almost every quads.
#47
Tekky:
Im 22, Mecanic engineer.
As you say, the banshee has alot of mods. If u knew anything about quad, you'd know that the banshee a quad made for being modified. I dont know any1 who has a stock banshee.
You say that 400ex lack power "STOCK". You are comparing a 400cc with 500cc. Add 800$ to the 400ex and its gonna beat the predator. I keep saying power isnt everything and u obviously cant understand that.
#48
Try to beat my 400ex in a track. GOOD LUCK!
the predator is like the raptor. Its a fuc king effel tower!
For those who talks about the explorer400. NICE STRAP ON THESE SHI T. keep sliding and sliding.
Ho yea! the polaris is gonna pass through that water plan and take the honda out of it.
Try to pull a big load of wood. the honda is gonna make it slowly but its gonna make it.
the polaris is gonna blow up or its not even gonna move.
For that guy who says the z400 is better than the 400ex! DID U EVEN TRY BOTH!?
My friend has a z400, i know what im talking about.
WAITING FOR REPLY!
WAITING FOR REPLY!
the 400ex seat height is 81cm....the preds is 81.3cm, wow SUCH a BIG difference....you cant even tell the difference...
and strap...WTF is a strap? do you mean belt? cus polaris quads are equiped with a belt....say it with me now, B - E - L - T, also after 97 or so, some quads will take in water through the carb before a PVT on a polaris will take in water. your so called "friends"(if any) quad must of had a crack in the seal....
also about the polaris not pulling a heavy load...lol, they why is the polaris 500HO have a higher towing rating than a rubicon 500, or even the 650? for the 500rubi, its over 300kilo's more, same with the rincon...at 386KG...the sportsman500HO has a towing cap of 556KG...
you can have your quad, while trying to turn under front shock compression, and getting bump steer...i would rather have a pred that has nearly zero bumpsteer...
wtf is an effel?!?! do you mean eiffel? lol, you sure dont act like a 22yrs old, i think you just wish you were....unless you can prove that, i wont believe you till you do
lol, add 800 to the pred, and adding only 800 to the ex wont even catch up to it.....adding 800 will probly get you the same handling characteristic as the pred, then ofcourse there is that slow honda 400 engine....ancient technology....air cooling, lol, last time i saw air cooling on a 03 model quad was on a mini, or a 250...
why cant you face the fact that the 400ex isnt considered a competable quad when comparing to the other sportbikes out there...rap, yfz, pred, DS...
#49
Oh, so you're a
huh? You can't even spell it. LOL. It would take a lot more than $800 for the EX to compare to the pred. Then we are talking about a highly modded quad versus a stock quad. Sitck that $800 in the Pred too and you can kiss your EX **** good bye!!! Thats how you Honda guys compare quads. You have to stick a boat load of money into your quad to come close to the STOCK performance of others. What a joke!! LOL. Honda, with their air cooled engines, drum brakes, 3 wheel drive. HA!!! What is this, the 80's????
Mecanic engineer.
