Any onfo on Magnum 425 4 stroke
Hey FTWFLH thanks for the reply, one question:
How does the Magnum 425 compare to your Sportsman 400? My dad has the same 400 Sprtsman that you have, and it is the best quad I have ever used, it wins at the mud boggs and ATV pulls every year. Just wondering how the two compare...I know that one is a 2 stroke so they are completely different, just shoot me straight either way.
Thanks
Cancat
Thanks
Cancat
The 400 has more hot power when the pipe kicks in and is a blast on trails but the 425 is a better all around machine lots of torque and power all the way through . They both ride and handle about the same. If you dont mind the 3 chains you will like the 425.I have had mine since 98 and other than hub probblems (my fault) the only thing I have had to do other than normal stuff like fluids and adjusting the valves is I had to replace the waterpump seal once.
exmotocrosser
09-13-2019 06:12 AM
BYC
09-25-2015 02:10 PM
Quadzilla Heritage
09-25-2015 01:39 PM
