Scrambler tie rod end replacement
I do realize this subject of tie rod ends is brought up frequently, but in my search, I found that the last post on them was in July or something like that. What's the new consensus on what to do when a guy gets to a point to need to replace them? '99 Scrambler 500 4x4
I saw someone tried to order a set from Grainger for cheap. How did that work out? What was the part number? My company is an OEM and we order tons of things from there, so accessibility is no problem.
There are two other companies that were mentioned, as well. MCR and EPI were the others. What are your opinions on these? My left outer rod end is thrashed after a hard weekend at Perry State Forest. Found the tie rod end that was bad when I was replacing my brakes. I will replace both outers while I'm there.
Thanks for your help in advance,
SnowDrift
SnowDrift
