tb 250 wheelies
Hey is there any mods I could put on my trailblazer to make it wheelie better? I mean like where I wouldnt have to stand on the Grab Bar I would just have to sit down and give it gas and pull up on on the handlebars a little bit maybe?
Would the RCR stage 1 kit with the Midrange pipe do this?
Originally posted by: Rancidgumbo
96trailblazer250, You must have made modifications to your braking system or your ATV is broken, because the left hand brake lever is a four wheel lever, it locks all the wheels, so with a stock machine that is in good condition, it is impossible to do what you're saying.
For the record, that is a very bad idea. Not only does it eat away at your brakes but it is also a good way to smoke a belt. They makes split brake kits if you want to do burnouts. But a higher engaging primary spring will help you to get the rpms up to go a wheelie. The Stage 1 is your best bet, but If you can't get that righ now, just have rick send you a new spring for now. They aren't that expensive
#16
Humm, I would get a BLUE spring... That would help you with wheelies... You can find them at www.hotseatperformance.com But if your getting the rcr stage 1 wait till you get the kit it comes with clutch stuff....
Hope this helps....
Hope this helps....
#17
thats weird i only way 125 and i can lift the front end as high as it can go..He// i fliped my quad backwards doing that once i had my feet on the grab bar in the back and mine is (stock) i dunno what ur doin wrong.......
