whats up with my brakes?
Old Dec 13, 2003 | 09:43 PM
scrambler420's Avatar
Default whats up with my brakes?
im not loosing any fluid,no matter how many times i pump it so im pretty sure its not leaking..
Old Dec 13, 2003 | 10:18 PM
talonhawk's Avatar
I think its in the master cylinder. Worn or foreign matteral on the
piston or fluid bypass valve.
Old Dec 13, 2003 | 11:36 PM
quadwrench's Avatar
In the master cylinder there is actually 2 small holes at the bottom of the resevoir (sometimes covered with a rubber "O" plug with slits that you can pop out) that 1 (or both) sometimes gets stopped up with the normal "old age scum". If both holes are not open, the m/c can't "breath" (allowing fresh fluid to replace the displaced fluid), which will not allow it to build up any pressure. If you are not loosing fluid, this will probably be the culprit - no need to rebuild, just clean it up good. I've found cutting torch tip cleaners work good for this (as well as carb jets too - just don't force a too big cleaner through the oriface)
Old Dec 13, 2003 | 11:50 PM
thanks ill check it out tomorrow
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
