plug kit
Old Dec 17, 2003 | 12:51 AM
BigBadScrambler's Avatar
Default plug kit
It must have to run off the intake manifold? If that is the case then it would require tapping a fitting into the intake. I dont like that Idea. It is hard enough to get to the spark plug, let alone the intake manifold[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 17, 2003 | 01:00 AM
fishslab's Avatar
Default plug kit
My guess is it installs in the case somewhere. I know some Tecumseh racers run pulse fuel pumps on their karts by running an air line from the case. Some do it with blow by from the head. THey use an adapter with an egr valve that lets oil over flow go into a catch can and an extra line to the fuel pump.
Old Dec 17, 2003 | 01:02 AM
Default plug kit
Sounds like a lot of work!!!. I think I may just get a C02 pump[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 17, 2003 | 02:20 AM
Traildog's Avatar
Default plug kit
Remove the spark plug and screw the hose in it's place. Hit the starter and you have a Limitless Comressor.
Old Dec 17, 2003 | 02:27 AM
  #15
fishslab's Avatar
Default plug kit
Great point. I realize if your stuck 20 miles from nowhere or further you do what you got too, but can you imagine having to tear down the Scrambler 500 on the trail to get at the plug. lol [img]i/expressions/face-icon-small-blush.gif[/img]
Old Dec 17, 2003 | 03:42 PM
  #16
RookWV's Avatar
Default plug kit
But with fuel mixed in....
Old Dec 17, 2003 | 09:36 PM
  #17
Traildog's Avatar
Default plug kit
RookWV, I agree that pumping a fuel mixture into your tires does not appear to be the right thing to do. I guess the amount is so small it won't effect anything??? I don't use this method instead I have a $10 air compressor that plugs into the 12 V outlet and this works great "limitless clean compressed air". The compressor is small enough to fit into the bottom of the Sportsmans tool compartment along with tire plugs and insertion tools.
Old Dec 18, 2003 | 10:09 AM
  #18
nubbin's Avatar
Default plug kit
Hi, I have a air compressor also. What I would like to know is do you have to use rubber cement with your plugs?. I am looking at a kit from Wal-Mart under $7. It has a rasp tool and a tool that inserts the plug and 4 plugs. The directions say nothing about using the cement. But in the atv calalogs I see in their kits they include rubber cement. Please help me on this. Thanks.
Old Dec 18, 2003 | 12:10 PM
  #19
RookWV's Avatar
Default plug kit
Yes, that's how the plugs stay in the tires.
Old Dec 19, 2003 | 01:03 AM
  #20
Traildog's Avatar
Default plug kit
Whether to use glue when inserting plugs? I have done it both ways with the same results. It is my belief that using glue is better but I've had great success with no glue. It is probably due to the type and quality of the plugs in the repair kit.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
frostphase
Aug 19, 2015 07:11 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
