shave piston
Old Dec 20, 2003 | 10:55 AM
getusummm's Avatar
Default shave piston
Trimming the piston actually goes hand in hand with porting. It is an area that you really need to be exact on. If you take too much off or open the ports too much the bike will run bad and actually lose power. I wouldnt recommend doing it yourself unless you can get exact numbers and the exacxt place to remove the material from. You may want to try macdizzy's site. they have alot of tuners and porting gurus there that can help you out. I think it is macdizzy.com. But you gotta hurry, they are gonna be a pay site starting jan.
Old Dec 20, 2003 | 07:06 PM
Bill35's Avatar
Ha go to macdizzy site to see alot of fake pictures...
Old Dec 20, 2003 | 07:42 PM
TWEEKER's Avatar
say bubba what would happen if you only widened out the exhaust port
Old Jan 15, 2004 | 05:54 PM
baxy's Avatar
the holes in the intake skirt are most likely for short circuiting the transfer ports so the A/F charge can bypass the normal circuit it makes around the crank
allows the pipe to scavenge alot more fresh intake mixture
I went from a stock 5/16 hole in my yamaha 600 mountain max to 1/2 and noticed a big difference no other mods and I grabbed 400 RPM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
