scrambler help
Old Dec 23, 2003 | 11:02 PM
TRoss0422's Avatar
Default scrambler help
ok...i have a 99 scrambler 400...and everytime i try to start it electrically, it just makes some clicking sound. I went and bought a new battery, but it still won't start; but it will with the recoil handle. I just went mudding about three weeks ago and didn't wash it for probably two weeks...just letting yall know incase that might be it. Anyway, just some ideas on what the starting problem could be.
Old Dec 23, 2003 | 11:05 PM
RookieRacer's Avatar
Electrical problems w/ the scramblers are semi~common from what i have learned from here. Could be something to do w/ the ground. Ask BIGBAD, He'll know. lol. Sorry I couldnt help ya out as much as you wouldve like to known.
Old Dec 23, 2003 | 11:16 PM
fishslab's Avatar
THe starters on these are prone to failure when put in contact with water and not drained. It may need to be taken apart and cleaned up. It may just need to be drained.
Old Dec 23, 2003 | 11:19 PM
2manytoys's Avatar
It is very important that after you ride in water or go mudding you need to drain the starter. there is a plug on the bottom of the starter just for this reason. It would also be a good idea to drain the recoil.
Old Dec 24, 2003 | 12:16 AM
Crawdad's Avatar
Pull your starter and check the brushes, chances are thats all it is. You can get a starter brush kit at your dealer if thats it. It's alot cheaper than buying a new starter. As these guys said, make sure you drain your starter regularly if you play in those muddy water holes alot.
Old Dec 24, 2003 | 12:40 AM
BigBadScrambler's Avatar
LOL RookieRacer!!
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
