Flywheel!?!?!?!?!?!?!?!?!
Old Jan 29, 2004 | 11:25 PM
Bubba297's Avatar
Default Flywheel!?!?!?!?!?!?!?!?!
I had Rick do mine and he got it done fast and returned it quick. No complaints here. The only thing is that the motor revved like it didnt have that heavy clutch pulling it down anymore.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 29, 2004 | 11:45 PM
badcompanyracing's Avatar
does rick rebalance them, i kno someone who had theirs done by him and his thumb throttle vibrates alot. is that normal?
Old Apr 7, 2004 | 03:38 PM
Redbullssg's Avatar
I know this is an old thread, but this is what I am thinking of doing. I hear "revs quicker" but how is it affecting the overall perfomance, accelaration , top end, etc. How dificult is this to do yurself. I work in the tool and die trade and machining won't be a problem. How can i balence it. and what exactly am I drill, milling etc. Pics would help. Thanks
Also after doing this, what other things do i need to consider? I have a hotseat pipe and clutch...
Old Apr 7, 2004 | 07:44 PM
TWEEKER's Avatar
I did my own in my laythe and it isn't ballanced and it vibrates less then when i had it stock just chuck it in a laythe make sure your with in a thou and use a good live center. i have the ring gear of so i took quite a bit off made big diff on excelleration and throttle response give it a try.
Old Apr 7, 2004 | 08:48 PM
  #15
modquad's Avatar
The flywheel lists for $190, so be careful if you're gonna do it yourself.
Old Apr 11, 2004 | 09:41 PM
  #16
I had Rick do mine, I dont know how much it helped since i lightened and changed the clutch setup at the same time. To bad my jug cracked and i found a hole in my case.
Old Apr 12, 2004 | 02:36 AM
  #17
iwannaatv's Avatar
i don't think losing engine momentum will make you go faster, sure you'll rev quicker and have more engine breaking but other than that, you could lose some power.
Old Apr 12, 2004 | 09:30 AM
  #18
Redbullssg's Avatar
I could see how it would work. It works on snowmobiles! I just have a lot of questions about it, that need answers before I do it!
Old Apr 12, 2004 | 02:20 PM
  #19
scramblered's Avatar
go for the HPD race flywheel,2,3 lbs lighter and no electric start as well,i still run that one for 3 years now,no problems at all,very easy to
pull start then and quicker.
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
