HPD High Comp piston 93 octane?
Old Jan 31, 2004 | 06:38 PM
Hozed's Avatar
Default HPD High Comp piston 93 octane?
motor is coming apart this week.. and ive been told that HPD reccomends 93 octane with there HC piston..
but by running 93 octane how much more power will it give me? ****.. i run 93 in it now! lol
Old Jan 31, 2004 | 06:48 PM
modquad's Avatar
The increased strength of the forge piston, it's lighter weight, and the higher compression....you win in every catagory. [img]i/expressions/face-icon-small-smile.gif[/img] Get ready to practice shifting faster, cause it'll rev quite a bit quicker.
Old Jan 31, 2004 | 06:49 PM
Hozed's Avatar
so you kinda need the cdi then huh... then i need to run race fuel.. JUNK!
Old Jan 31, 2004 | 11:57 PM
jammer42's Avatar
You do not need a better cdi to run the 12.5 piston.Running good fuel has more advantages than power increases.
Old Feb 1, 2004 | 09:40 AM
Hozed's Avatar
i dont NEED the cdi but if its gonna rev real quick than it would be quite nice.
i know race fuel is better for the engine with a HC piston.. but will the 93 octane and HC piston show very much power gain?
Old Feb 1, 2004 | 03:48 PM
thomez's Avatar
Octane does not give you power.
Old Feb 1, 2004 | 11:51 PM
JEFF10049's Avatar
Ok so heres how it works octane is a fuels resistance to detonation the higher the octane the harder the fuel burns. so running the lowest octane you can get away with without pinging will give you the most power it will combust better and burn compleatly so right now with stock compression it dose not need 93 so you probably did not notice much right? but with the higher comp. you will need it and notice it higher comp. = higher cyl. temps makeing the resistance to detonation nessary it will light before the spark otcreating a ping. with lower octane fuel.
2003 trailblazer250 RcR stage 1 milled head
Jeff
Old Feb 2, 2004 | 01:10 AM
predatorracer's Avatar
I am thinking of going with the big bore high com piston, and I have the vortec cdi. What would be the best octane to run. I am running ultmate 4 fuel from vp now, which is 92.2 octane. I love the extra punch but, was wanting to run something a little easier on the wallet, 8.50 a gal is getting to be to pricey!!!
Old Feb 2, 2004 | 01:13 PM
thomez's Avatar
What compression will it be?
Old Feb 2, 2004 | 05:17 PM
Hozed's Avatar
12 5 1 i think
