AAEN PIPE, CLUTCH KIT, i need help
Old Feb 1, 2004 | 10:04 PM
NY400scramblerrider's Avatar
Default AAEN PIPE, CLUTCH KIT, i need help
well, this fall i bought a 1995 polaris scrambler 400 4x4, & i had done my homework, i know i did'nt want stock, i wanted a pipe, & possibly bored, which this had, i apid $2,200 & was a good deal, i did my homework, but it's truly a good quad & lots of my friends(i'm a highschool kid) so they want japanese, and say i don't want to shift. so now my top end is garbadge, i was on a road riding w/ my friend, he's got an acritc cat 250 utility & he even pulled away a bit, somethings wrong here?????, so i get to thinking & a distant relative who use to be a polaris mechanic says "when u put most after market pipes u gail low & mid, but your can kiss your top end goodbye" which i love dearly, but my wheeler just needs the top end, so i'm hoping u can understand my dilema, i need to first off check my belt, it may be loose or worn, that could be it, also i need to throw my dennis kirk catalog in the trash, because they have nothing good for polaris, performance, so now i'm thinking if my belt checks out, i'm gonna put a HOT SEAT, HYPERSHIFT CLUTCH KIT in w/ an AAEN TOP END PIPE, this will give me top end & it also shift too fast, i need it to hold back for more of a slap, or punch, it just seems to lay down & die right now, so let me know what u think.
- CAN I STILL CRAWL THROUGH MUD W/ CLUTCH KIT & GO FAST, & ALSO WILL I BE ABLE TO WALK IT OVER BACKWARDS & GET THE LOW/ MID RANGE W/ THE AAEN TOP END PIPE, THANX.
Old Feb 2, 2004 | 07:57 AM
ftwflh's Avatar
go with either Aaen topend pipe or HPD pipe or RCR which ever you choose get the clutch kit THEY recomend for thier pipe.MY ask them about the carb jetting for the pipe they can get you real close if not right on the money.All three of these have get customer service.
Old Feb 2, 2004 | 09:30 AM
xxxracerxxx's Avatar
you will get good top end i lost bottom end with dg pipe and gained a lot of mid and top end
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
