Xplorer 250 grinding noise..
Old Feb 2, 2004 | 04:12 PM
tyler711's Avatar
Default Xplorer 250 grinding noise..
Hey-
I'm not really that educated about ATV's, but i have a polaris xplorer 250. I recently got it registered, and am enjoying driving somewhere other than in my own woods. But recently the atv has been making a grinding noise. It sounds like its not in gear all the way, but even when i hold the shifter forward it still makes the noise. It is not constant, but usually occurs when i am accelerating or driving up a long incline. It is coming from somewhere inside the engine or transmission area, not from a hub or differential. Any suggestions as to what it might be would be appreciated. Thanks
Tyler
Old Feb 2, 2004 | 05:04 PM
50021's Avatar
ok, I like to do things myself, but if i was you i would take this to an expert, You most likely have a shot tranny, which is somewhat costly to replace
Old Feb 2, 2004 | 05:54 PM
Polaris500HO4x4's Avatar
where does it sound like its coming from.
Old Feb 2, 2004 | 06:44 PM
tyler711's Avatar
I havent been able to pinpoint the noise- it isnt constant, and it never happens when im waiting for it of course. I havent done much rough driving, though. Just light trail riding over packed dirt and some light snow, and i use low on the big hills and deep snow.
When im riding, it feels like the noise is coming from right under the back of the seat; right under where im sitting. But there isnt much there on a 250, so i dunno. And i can feel it too, the atv kinda jerks a tiny bit, which makes me suspect a transmission prob. Its only two years old though, and like i said, no real off roading on it, just light trail riding...
Old Feb 2, 2004 | 06:47 PM
50021's Avatar
is it still on the warranty?
if so see what the dealer says, sounds like a tranny problem if it is jerking like you said
Old Feb 2, 2004 | 06:53 PM
tyler711's Avatar
Thanks for your help... i'll check the warrantee, but i dunno.. the 250's the cheapie one [img]i/expressions/face-icon-small-wink.gif[/img] I think ill get it to the dealer and see what they say.. *cringe*
Old Feb 3, 2004 | 04:47 AM
atvguyinmaine's Avatar
Check the chain...it can make a grinding noise......could be way to tight..or loose...check the sprockets also....just a thought
Old Feb 3, 2004 | 09:14 AM
billygoat21's Avatar
Definitely check your chain. I have a 2001 xplorer 250 and the same thing happened on mine. The polaris chains seem to strech very easily and when your chain gets loose it makes a noise from hitting the sprocket wrong. Check your chain before every ride!
Old Feb 3, 2004 | 04:11 PM
tyler711's Avatar
thanks, will do the next time im outside... lotta homework today [img]i/expressions/face-icon-small-sad.gif[/img]
atvguy, u think it could have anything to do with the cold we've had this winter up here? i was out when it was a good bit below zero a few times [img]i/expressions/face-icon-small-happy.gif[/img]... just wondering if it could do anything
Old Feb 3, 2004 | 06:27 PM
xxxracerxxx's Avatar
if you rev the motor in netural and don't let it rev down when you shift into foward it wll grind until the rpms are down enough
