counter balance question again??
Old Feb 5, 2004 | 11:07 PM
mabell1's Avatar
Default counter balance question again??
i was going to replace the oil seal and waterpump seal on my scrambler. i have noticed the shaft on the counter balance is pretty marred up. i tried to clean it off with a soft wire brush, but it seems to have some grooves in it. It also have a good bit of play in it. i think it may have also been leaking oil and antifreeze into the crank. Do you guys think i should replace the whole counter balance. there is no play in the crank gear. If i should replace the counter balance where is the cheapest(lol) place to get one?? thanks again
Old Feb 5, 2004 | 11:16 PM
duneaholic's Avatar
You can get a rebuilt one for I think 75.00 from Rick Ritter less the core.
Ritter Cycle
Old Feb 5, 2004 | 11:25 PM
mabell1's Avatar
great thanks
Old Feb 5, 2004 | 11:38 PM
Whitedog's Avatar
Mine was worn bad too. I took it to a local machine shop, and they spray welded it then turned it down on a lathe. Works pretty nice so far.
Old Feb 6, 2004 | 04:42 AM
700quadman's Avatar
Be sure that you replace all bearings and seals too.
-700quadman
Old Feb 6, 2004 | 07:48 AM
ftwflh's Avatar
I have used a good grade of epoxy and emory cloth and filled in the grooves and is worked.
Old Feb 6, 2004 | 04:17 PM
mabell1's Avatar
i have jb weld. will that work on the grooves. and can i sand that stuff to smooth it out after it dries. thanks
Old Feb 6, 2004 | 06:23 PM
ftwflh's Avatar
I used it and it worked but if you try keep an eye on it for awhile to be on the safe side.
Old Feb 6, 2004 | 06:52 PM
mabell1's Avatar
how did you apply the epoxy? and did you sand it to smooth it out??
Old Feb 6, 2004 | 09:25 PM
ftwflh's Avatar
Just a small dab in the groove and polish it smooth
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
