Pred maintenance
Old Feb 7, 2004 | 06:02 PM
Bradracer18's Avatar
Default Pred maintenance
Hey guys, I am getting ready to go to little sahara in about a week. I was just wondering if you guys could give me a few tips on what I should check/do before I leave to keep break downs to a minimum. I have changed the oil and I have the shocks adjusted. My k&n is clean and carb is tuned. It is greased too, what other maintenance things am I forgetting?? Thanks for all of the help. One more thing, what are the advantages of a different oil tank?? Where can I get one?? Thanks again Brad
Old Feb 7, 2004 | 06:15 PM
RuckusRacing's Avatar
Besides what you mentioned I usally: adjust & lube the chain, check tire pressures, check & adjust clutch & throttle cable if needed, check brake pads, and check nuts & bolts to be sure everything is tight.
Have a safe trip!![img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 7, 2004 | 11:06 PM
Sniclefritz4's Avatar
bring an extra 4-wheeler(just in case)
dannytas
Sep 26, 2017 06:31 PM
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
