new water pump seals still leaks??
Old Feb 11, 2004 | 12:06 PM
mabell1's Avatar
Default new water pump seals still leaks??
i put a new oil seal and water seal in my scrambler. the counter balance shaft did have some small grooves in it. i sanded it down a little and got it as smooth as i could. it is still get coolant out of the weep hole and in the counterbalance oil. The motor also vibrates alot. this is really the first time i had it running, so i dont know if that is normal. i did check all the motor mounts and they seem ok. Do you guys think the counter balance needs replaced?? and would this cause the engine to shake alot? someone told me on here that rick ritter sells rebuilt counter balancers for around $75.00. thanks again for your help
Old Feb 11, 2004 | 12:19 PM
CED's Avatar
CED
Did you align the marks on the gears.If you didn't,that's probably why you have a bad vibration.The seals are different ,if you didn't put the right one where it goes it will leak like crazy.If everything is correct then you may need to get another balancer from Rick.Hope this helps.
Old Feb 11, 2004 | 12:45 PM
mabell1's Avatar
I didnt pull the balancer out. yes i triple checked to make sure i put the seals in correct. When i pull the balancer the manual says to line up the punch marks on both gears, but i dont see any punch marks. can i just mark the teeth on both gears? i dont have to pull the piston do i?
Old Feb 11, 2004 | 02:44 PM
mabell1's Avatar
never mind i just blew the case apart. thanks anyway
Old Feb 11, 2004 | 02:52 PM
CED's Avatar
CED
You mean blew it apart as in broke it.
Old Feb 11, 2004 | 02:58 PM
mabell1's Avatar
yeah, i drained the cb oil and refilled it just to make sure the oil seal was leaking. drove it for about 3 minutes and i guess one of the bearings flew apart, because something blew through the case. i just posted another message about buying a rebuilt motor from pmc. i am sick of messing with this junk i bought. i should have new better than to buy it it didnt run. oh well, live and learn i guess. what do you think i should do now???
Old Feb 11, 2004 | 05:00 PM
CED's Avatar
CED
That sucks.Give Rick Ritter a call,he can get you brand new cases with the bearings and seals for around $280.Good luck.
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Sportsman850
Jul 31, 2015 04:25 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
