Cutting plastic
Old Feb 11, 2004 | 11:09 PM
Christopher325's Avatar
Default Cutting plastic
Ok i have a 2000 trail boss... and i was wondering how you would go about shaving the front and rear fenders... also if anyone knows how to remove the front fenders... i would appreciate it alot thx
Old Feb 11, 2004 | 11:33 PM
Whitedog's Avatar
I used a dremil tool, worked nice. I notched the back fenders on the back, where i wanted them to be then stretched a string down to the bottom, where I thought they looked good. Then used a sharpie marker to trace the string. then cut with the dremil. I did the front basically th same way. Dont forget to measure, measure, measure! (both sides) U dont want to cut em uneven. Oh yea leave em on the bike when u cutem. Hope this helps. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 12, 2004 | 02:40 AM
modquad's Avatar
That's the exacting method. [img]i/expressions/face-icon-small-smile.gif[/img] Very precise. I use the eyeball engineering. Grab a grease pencil. Draw an outline. Grab a tin snips for the rough cut. Smooth the radius w/ crosscut file and a sanding block.
Old Feb 12, 2004 | 11:11 PM
BT250racer's Avatar
i drew mine on with a marker until i thoguht it looked the way i wanted it to and to get the other side the same i just heated up the plastic i cut off and fliped it around and bent it to fit on that side then drew the line and i cut it with a razor and smoothed it out with a dremal
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
Old Feb 13, 2004 | 05:47 PM
fidge1's Avatar
Use a dremel, you can get good details and curves with it.
Old Feb 13, 2004 | 06:31 PM
badcompanyracing's Avatar
i used a rotozip, worked good
Old Feb 13, 2004 | 07:10 PM
Maddog419's Avatar
You can use a tire grooving iron also, works great. I would practice alittle tho. Cut it from the bottom side.
later
Joe454
Nov 20, 2020 01:19 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
