Piston Pin Stuck, Use Propane torch to get off?
Old Feb 11, 2004 | 11:27 PM
1998trailblazingfool's Avatar
Default Piston Pin Stuck, Use Propane torch to get off?
My friend has an idea of getting my piston pin off by getting the top of the piston warm and than letting it warm the pin so we can than hit it out. I kinda fried my piston in the midrange and melted a lil hole on the top of the piston, so now i'm buying some stuff so it doens't happen again.. Whats your guy's imput???
Old Feb 11, 2004 | 11:44 PM
trailrider500's Avatar
That is just going to make it worse aluminum expands a lot when heated and it will just make it harder...
You can make a tool like it did for this.. Get a piece of all thread, pipe a few washers and nuts.. This tool will work if the wrist pin is hollow all the way through... If you want a pic of this tool PM me with your email addy and i will send you a pic of it and how to make it...
Old Feb 11, 2004 | 11:46 PM
don't get me wrong heat will help but a little propane torch just wont work its either a lot of heat or none..
Old Feb 11, 2004 | 11:47 PM
JEFF10049's Avatar
Is the pin stuck in the piston or the rod? does it move at all? if it's stuck in the piston then you could try heating the piston it should expand more than the steel pin.
Old Feb 12, 2004 | 02:31 AM
modquad's Avatar
Either of the above, or just get a piston pin puller. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 12, 2004 | 09:18 AM
Russ7R's Avatar
I have a little trick for you....it works on outboard motors, basicly the same, put it in the freezer until it is cold/frozen than heat the piston.
The piston is alum and will swell faster than the pin and rod so it will just about fall out!
Good luck,
Russ
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
