Polaris Receiver Hitch
Does anyone know where I can get a 2" receiver hitch mount for my '04 magnum 330 4x4? I have seen mounts for the chain drive bikes and the independent rear suspension bikes, but the magnum has neither. I don't care who makes them......even if you have a buddy who can fabricate one. I just need a 2" receiver mount. Any help would be appreciated.
Try www.jackssmallengines.com they have some hitches (2" receiver) that might work!
Get a piece of 2" id square tubing and drill a hole the same as the hole on your hitch( I think the hitch comes out at an angle) then attach to your bike and set it so it points straight back. Mark this on the tubing and get stoppers welded on to stop horizontal movement. Drill holes for the pin and you should be able to put any hitch on you want.
I bought mine from Cabelas just a couple weeks ago. It was sized as "ALL POLARIS SHAFT DRIVE." I had to make a cut on mine so it would clear the protruding transfer case but I think it was made for your specific application. Does the Magnum have a ball mount with 2 holes in it? Mine has a big hole with smooth contoured sides like what you could use to run a tie down thru as well as a hole that accomodates a ball mount. The Cabelas hitch utilizes both of those holes for attachment. It's a clean, strong install.
www.cabelas.com
www.cabelas.com
