help with scrambler
Old Feb 23, 2004 | 08:48 PM
  #21
xxxracerxxx's Avatar
Default help with scrambler
bad reeds
Old Feb 23, 2004 | 09:06 PM
  #22
ATVBos's Avatar
So this is a 2-stroke
my bad
Old Feb 23, 2004 | 09:15 PM
  #23
blue250r's Avatar
How long was your bike out of action?
The fuel goes off after a while it looks and smells the same but doesent fire very well i have seen this a few times myself after winter or long rebiulds drain the tank and carb and put in some new stuff [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 24, 2004 | 12:12 AM
  #24
scrambler123's Avatar
It's not the reeds i pulled them out and checked them. It is brand new gas also
Old Feb 24, 2004 | 11:32 AM
  #25
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
well
if you have compression, fuel and spark you should run
I would retrace my steps and check everything again
maybe too much fuel?
Old Feb 24, 2004 | 11:51 AM
  #26
CED's Avatar
CED
Check your choke cable and make sure the plunger on the end of the cable is seated all the way down in the carb,i had this mess up on me once.If you hold the carb in your hand you can see in there where the plunger sits.Hope this helps.
Old Feb 24, 2004 | 12:25 PM
  #27
700quadman's Avatar
Sounds like a fuel supply issue to me since it fires up then dies after burning the fuel in the cylinder. Check for fuel at the carb, check your gas tank vent, look for water in the tank and carb...
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
