cheap upgrades for scrambler
Old Feb 24, 2004 | 10:26 PM
csamayfield55's Avatar
Default cheap upgrades for scrambler
Call Rick ritter at Ritter cycle racing and ask him what he recomends.
What the spring change will do is raise the rpm your belt engages and give you more of a snap off the line.
Chris
Old Feb 24, 2004 | 10:29 PM
tbsleeper's Avatar
i would wait to get new clutch springs because if u ever get a pipe ur gonna have to buy a whole new clutch setup. also maybe just spend 325 and get the rcr stage 1 kit. www.rittercycle.com
Old Feb 24, 2004 | 10:38 PM
Jayblazer's Avatar
you dont want to mess with your clutch yet it will just mess up your jetting. if you have 200.00 to spend before you jump into mods you should check out the stuff on the quad that needs replaced every now and then like
chain
sprockets
counter balance"really check this one out its something every one with the 400 needs to keep an eye on"
fluids counterbalance oil transmission oil brake fluid and coolant
bearings in the front wheels and rear swing arm
shocks the rear fox probably needs charged
reeds just go with the stock ones now till you know everything else is in good order
cables to throttle and oil pump need adjusted every now and then
vent lines these all need ran to the right place
tires
and that should get you started....
good luck listen if you want dont if you dont.
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 24, 2004 | 10:59 PM
iwannabfast's Avatar
thanks ill do that
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
