How fast will a 700 Sportsman Go??
Had my 04 (carb version) up to 70 on speedo and with GPS. Spedo is accurate, as I have seen on any ATV. I have to agree with others it is stable as can be. Mine actually has factory wheel weights on the front to keep the tires balanced. I have never seen this before. Wonder what happens if I lower the psi in the front tires?
#15
#17
Polaris, limits the speed two ways. 1 which is an easy fix, is the white nylon nut on the primary clutch to limit how far it shifts out, simply remove gain 1-2 mph. Second, which I don't know of a fix is the CDI and how the timing retards at higher RPM. Perhaps the CDI of the 4 stroke sled will snap right in.
