pred jetting....
i put my clamp on last fall... went to a 172.5 MJ and a 50 PJ... that was all i changed....
went to put my box back on because of mud water and i heard of the lost performance... put everything back the way it was before my clamp on... and at half throttle and above it cuts and pops like a MFer.... what could have happened...
You need to move your clip on the needle back to the 2nd notch, run a 45 pilot, and 150 main and it will run fine,, Make sure all the snorkal lines and air box is sealed properley. My pred is running mint with a clamp on and a 45 pj, 175 main, and needle on the 5th clip... def increased some hp,, but will have more when i get my original motor in it... Make sure all that is correct and then try it, there is no way that it can run shi**y,
Hankey Pankey
26
Oct 18, 2020 03:50 PM
BYC
Sep 25, 2015 02:10 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
