Rick or Bubba
Old Mar 29, 2004 | 12:03 AM
Blazer250's Avatar
Default Rick or Bubba
Hey Jeff, I don't get the concept of this "gas porting." Can you explain to me in dummy language how this works? Do you drill clear into where the ring sits? Sorry...I'm a little slow.
Old Mar 29, 2004 | 01:02 AM
mudmaster250's Avatar
gas porting check this out it will tell u how to do it. by the way jeff have u torn into it yet to check the wear?
Old Mar 30, 2004 | 11:18 PM
JEFF10049's Avatar
Yes blazer you drill into the ring land behind the ring from the top of the piston and the cyl. pressure helps force the ring outward and thats all there is to it. Just a way to get a little better ring seal.
Jeff
Old Mar 30, 2004 | 11:34 PM
JEFF10049's Avatar
Mudmaster I have not checked the wear yet. Still getting enough hours on it too make it a good test I have too put the same amount of hours on it as pre gas porting and then measure the bore, ring gap, and piston skirt. Then compare the wear amount to the pre porting specs. It won't be long now.
And if it's not to late I saw you other post and I have the HPD mid. pipe on mine (had to 2003) and love it the midrange is killer and the top is good to If you want bottom you'll have to set the clutch stall high. Got mine from RcR. By the way if you don't want it loud then tell rick to hold the silencer and get you a stock 400 one fits right on. You can have my Hpd MSA silencer for a deal if you want it I took it off after one ride and went with the 400 silencer.
Sorry for the slow replys been gone rideing came back and I'm 10 pages behind!!! Need wireless internet LOL.
Jeff
Old Mar 31, 2004 | 12:58 AM
  #15
its not to late, im still tryin to convince mom, its getting down to the wire too. were heading to the badlands on april 9th. im thinkin about the polaris silver clutch spring(i think thats what 2manytoys said to get) and a stock 400 carb thats bored from rick. i think that i will just go ahead and have rick send me his silencer so i can get it done if i can order it but later down the road i may sell it and buy yours if u still have it or juts keep mine and buy yours so i can havee a sprak arrested silencer.thanks, scott
Old Mar 31, 2004 | 01:32 AM
  #16
mistertinker's Avatar
if you have it apart again could you take pic of the gas ported piston and post it?
Old Mar 31, 2004 | 01:43 AM
  #17
one more question. will the ports eventually get stopped up or filled with carbon and have to be opened back up?
Old Mar 31, 2004 | 09:50 AM
  #18
Bubba297's Avatar
A good quality oil running 40:1 will keep things down on build up. Remember that the piston ring wear will be more and the top end would need rebuilding sooner like that. More performance always means more maintenence.
Old Mar 31, 2004 | 09:47 PM
  #19
JEFF10049's Avatar
yes I will take a pic. next time it's apart I wanted too when I did it but. the cramera was at home.
cowboy
Mar 24, 2001 07:12 PM
polcat2
Nov 7, 2000 10:40 PM
fourlix
Oct 23, 2000 09:32 PM
IndyDave
Oct 12, 2000 12:51 PM
94DGblaster
Jul 14, 2000 09:57 PM
