skidoo snowmobile engine with a scramy trany?
one of my buddies is trying to put a skidoo snowmobile engine on a 400 scramy frame. the problem is he needs a transmission. will a transmission from a 400 scramy/sport work on the skidoo engine?
all replies greatly appreciated
thanks
ross
[img]i/expressions/face-icon-small-cool.gif[/img]
thanks
ross
I just installed a rotax 700 into a sport frame ,the problem you run into is the clearance for the carbs.So i did away with the tranny and did a jackshaft instead,which gives you more clearance.Send me your e-mail and i will send you some pic's monday.
By putting in the Ski Doo engine (I assume your going to use the TRA ski doo primary clutch) I don't think you can get a strong enough converter (secondary clutch) spring to keep it from overpowering the clutch and sucking in the belt. You may need to look into modifying the secondary setup to a Ski Doo snowmobile secondary clutch also. Then you can just put in stock clutching for that motor when it was in a sled and be close on your setup.
07-30-2015 09:39 AM
KimSJoh
14
07-18-2015 07:20 PM
