Mega coolant leak
Old Mar 14, 2004 | 08:10 PM
trailrider500's Avatar
Default Mega coolant leak
Remove the plastic, Run it till coolant comes out, find exactly where its coming from... Then i would go from there..
Also crank the engine with the radiator cap off if coolant starts to shoot up it could be a blown head gasket.. Inspect your radiator for cracks etc, Check all hoses, if all that checks out good then its down to your water pump and thermostat or your pressure cap(check to see if its coming out there)..
Also does your fan turn on during this time?
Old Mar 14, 2004 | 08:11 PM
Also a service manual would come in handy... You can get one at your dealer. I paid 35 for mine...
Old Mar 14, 2004 | 09:48 PM
lslubecki's Avatar
Test the thermostat in an pan of water. Heat the water and moniter it with a thermometer. If it opens at or near the rated temperature its ok. If it doesnt, Polaris wants about $90.00 for one in Dayton Ohio. Good luck.
Steve Lubecki
Old Mar 14, 2004 | 10:46 PM
peteyz24's Avatar
90 bucks for a t stat, screw that id just leave it out then, but i dont ride the quad much when its cold
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
Kenidah
Sep 7, 2015 07:50 PM
