heelclicker and belt wear problems
Old Mar 27, 2004 | 04:14 PM
tack's Avatar
Default heelclicker and belt wear problems
I put a heelclicker in my sp700, but I didn't notice much of a change until I put the orange spring in the primary. It really woke the machine up, but the engagement seemed high. I put the stock primary back on today and noticed belt residue on the inside of the belt cover, way more than it should. I put a new belt on about 2 weeks ago and cleaned the whole clutch area, so I know it's all new. I use the machine for logging and pull an arch behind it and was wondering if the high engagement could cause the belt to slip more under a heavy load. If so, how should I set the clutch up? I did change the tip weight by removing the washer in hopes of giving the belt a little more squeeze. Thanks
Nondem
Feb 22, 2020 12:20 PM
Captjay
Jul 23, 2015 12:33 PM
hondarider1234
Jul 21, 2015 11:53 PM
trouttracker
Jul 20, 2015 11:54 AM
black_thunder
Jul 9, 2015 05:58 PM
