too much oil
Old Mar 27, 2004 | 06:35 PM
muddin's Avatar
Default too much oil
is running too much oil bad for the atv?
Old Mar 27, 2004 | 08:32 PM
modquad's Avatar
It's not good. [img]i/expressions/face-icon-small-smile.gif[/img] Whether it's a 2-stroke or a 4-stroke, you should keep mixtures and levels at manufacturers suggested levels.
Old Mar 27, 2004 | 09:50 PM
kybabyn's Avatar
to much oil can cause it to foam and sloah and even eventually seize parts
Old Mar 28, 2004 | 01:52 AM
DANO38's Avatar
okey, so i agree with all that too much oil is not good, but can anyone tell me why when i bought my 03 sp 600
the dipstick showed it was over full, and when i change the oil and filter, and refill it with 2 qts per my dealer and
the manual it still shows overfull by almost 1/2 inch????
Old Mar 28, 2004 | 07:23 PM
HornedToad's Avatar
Dan, I don't have a good answer for you but when I bought my 2004 Trail Boss it was about 3/4 inch overfilled, as shown on the stick. Of course the dealer said he "checked it" prior to delivery. BS. So I sucked the excess oil out until it met the Full mark. Then when I changed oil/filter the first time I simply added oil up to the Full mark and had some left over from my 2 quarts (after starting the engine to fill the filter). One of life's mysteries! Bottom line: I would go with the dipstick level Full mark as the final determination.
EW
Old Mar 28, 2004 | 11:52 PM
Lukester's Avatar
Right again HornedToad! Same thing here. When I screwed in the oil dipstick to check the oil, it was high - new from the dealer. Now I just go by the stick.
Hey Toad, I still hear you screaming when loading that boss. Did you get ramps (LOL).
Lukester
Old Mar 29, 2004 | 12:35 AM
TreeDoc's Avatar
Checked mine yesterday in the new 500HO....about 1/2" over the full mark! I'll be doing my 10 hour change in about 5 more hours of ride time so I think I'll pull a little out now and check the level after my oil change.
Old Mar 29, 2004 | 08:41 AM
scootergptx's Avatar
Supersock
Hired Gun!
My nephew wanted to ride the wifes Trail Balzer. Told him to bring me the dipstick to see how much oil was in it. After a while he gave up and asked to ride my Boss. [img]i/expressions/face-icon-small-happy.gif[/img] 2 quarts and a filter puts the level just above the full mark on the Boss.
Old Mar 29, 2004 | 10:19 AM
xcrider's Avatar
Correct my if I wrong but doesn't the manaul say to run the ATV for about 20-30 seconds and then check the oil level on the dip stick?
Old Mar 29, 2004 | 04:54 PM
wagntwister's Avatar
The capacities (sp) are for a dry engine,trans, or whatever you are filling. I just changed all of my fluids today on a 04-500HO and it took about 1 1/2 qts. of oil the book calls for two. Also the other fluids I put in were a little less than the book calls for. This is due to not being able to drain everything dry.
