Hooking up a horn: Will it work?
Old Apr 3, 2004 | 12:03 AM
  #41
AKracer's Avatar
Default Hooking up a horn: Will it work?
K, just to get this straight one more time before i do it, all i need to do is attach that one purple wire comming from the button to the horn, and the ground wire that came with the horn to the bolt that the other ground wires are connected too? I dont need to cut any other wires?
Old Apr 3, 2004 | 12:10 AM
  #42
BigBadScrambler's Avatar
Correct. Although my ground wire just attacted to the bolt that held the braket to the horn. It grounded itself VIA the frame. But yes, cut that purple wire coming from the button, and tape the one end off and solder a longer wire to the other ind coming from the button and connect that to the horn. Thats how I have mine set. Dont solder anything until you make sure it works
Old Apr 3, 2004 | 12:19 AM
  #43
AKracer's Avatar
alright, ill give it a try. thanks.
Old Apr 3, 2004 | 01:36 AM
  #44
AKracer's Avatar
still not workin
Old Apr 3, 2004 | 01:38 AM
  #45
AKracer's Avatar
I connected that purple wire to the horn, stuck the ground wire to the bolt, turned the key on and pushedthe button. Nothing happened. We hooked up a grey and orange i think it was wire that was by the pruple one tothe batter, and hooked the pruple wire to the horn. Now the horn was on constantly. I just dont get it.
Old Apr 3, 2004 | 02:28 AM
  #46
AKracer's Avatar
ok, heres the thing, I hooked up the grey and orange wire to the batter, the purple wire to the horn, and had a wire from the horn grounded to the frame. now what happened? it went in reverse. the horn would be constantly running, but when you press the OR button, the horn stops. its doing the opposite.
Old Apr 3, 2004 | 09:05 AM
  #47
MrToys's Avatar
AKracer, no you can't hurt the coils if you don,t have awd,but you could hurt the gear selector switch at the trani if you have a 2x4. BBS thanks for the reply, still alittle confused, did you cut the gray/white wire or just splice the red/white into it. AKracer you should not be appling power to the gray/orange wire. I will try and post the wiring diaghram of the reverse override in before and after format. Just give me a day. Good luck guys.
Old Apr 3, 2004 | 12:21 PM
  #48
MrToys's Avatar
Okay guy's I hope this helps. I've uploaded two more picks in my pictures. The reverse override picture shows factory wiring. The picture named reverse mod is what you need to do for the reverse override. The two wires labeled for horn use can be hooked up any way you want. Now BBS correct if i'm wrong but i think you did almost the same thing except you did not cut the gray/white wire, you just spliced with the red/white. Which after viewing wiring diaghram again looks like it should work with no ill effects. I would still use a relay to power the horn or horns. Have fun and let me know if this helps.
Old Apr 3, 2004 | 03:38 PM
  #49
Mr Toys, I believe so. The gray/orange wire is unpluged. There is a jumper wire spliced between the gray/white wire and the red/white wire so that they are both hot.
Old Apr 3, 2004 | 03:39 PM
  #50
AKracer's Avatar
I dont see a grey and white wire....
