Hooking up a horn: Will it work?
Old Apr 1, 2004 | 03:32 PM
  #21
jtrundle's Avatar
Default Hooking up a horn: Will it work?
We will be awaitin'!
Old Apr 1, 2004 | 10:00 PM
  #22
MrToys's Avatar
Hi guy's i posted a couple 3-4 weeks ago on how to do the reverse overide with no parts. After performing the reverse overide both wires to the overide switch will be disconnected and open for horn use. Also doing the overide the way i posted lets the dash lights work properly. Here is the thread for the reverse override.
http://forums.atvconnection.com/mess...hreadid=385626
Old Apr 1, 2004 | 10:09 PM
  #23
Snowride's Avatar
Wow, those are old. Them be my instructions. Enjoy
Old Apr 1, 2004 | 10:10 PM
  #24
AKracer's Avatar
well now what should i do? those instructions you posted, mrtoys, is for a scrambler, will it also work for a trailblazer?
Old Apr 1, 2004 | 10:13 PM
  #25
Snowride's Avatar
Actually those instructions were written for the Sportman and Xplorer but may work on others.
Old Apr 1, 2004 | 10:25 PM
  #26
MrToys's Avatar
As I stated in the other thread those were not my instructions, but of all the override instructions i have come across the one by snowride works the best and yes it will work on a trailblazer.
Old Apr 1, 2004 | 10:30 PM
  #27
AKracer's Avatar
i found this in an old topic:
"I would use the over-ride button on the ground side of the horn, Your best bet would be to run the positive side of the horn directly to your battery with an inline fuse attached, That way when you press the button the ground completes and horn beeps. "
That will work, wont it?
Old Apr 1, 2004 | 11:02 PM
  #28
MrToys's Avatar
that will work but i would be very careful on how many amps the horn draw. it doesn't matter if you use the negative or positive side of the horn, a horn still draws a certain amount of amps and in time will short out the override switch. but it should work for a while.
Old Apr 1, 2004 | 11:13 PM
  #29
AKracer's Avatar
wont the relay keep that from happening though>?
Old Apr 2, 2004 | 12:05 AM
  #30
MrToys's Avatar
yes the relay will fix that and it does n ot matter if you use the override switch to control power or ground to signal the relay.
