tach for 4-8 cylinder auto-will it work
Originally posted by: bodean
I have a brand new auto-pro analogue tach and was wandering if there was any way possible to hook it up on my '02 5000ho x sportsman.If so can someone tell me how to do it,thanks bodean------'02 500ho x sportsman
Actually you can use a tach/hour meter that they sell at lawnmower parts/repair shops for either 2 or 4 strokes - it has an inductive lead that wraps around the spark plug wire, and an LED readout -- the one I am familiar with is made by SenDEC (model # 806-100-0222), has a Rotary part # 32-9359, reads up to 9,000 rpm, runs around $50 and can be mounted just about anywhere
HERE is one I found on Ebay that ends in a couple of days.
I use one of those for our lawnmower rpm setting. The bad thing about it is that it doesnt read fast enough changes for me. Brad, buy the cheapest,smallest tach and set it on the 4-cylinder setting for your 400 2-stroke. They actually read well until about 7500 or farther.
07-07-2015 11:00 PM
