Predator stalling question
Old Apr 12, 2004 | 07:03 PM
BoatGuy's Avatar
Default Predator stalling question
2 things.....
I'm not buying a yfz(unless maybe for a backup bike), and that doesn't help what is happening to my bike.
Old Apr 12, 2004 | 07:35 PM
Predator19's Avatar
Sounds like a carb problem....I would pull the plug first thought and see whats up.
Old Apr 12, 2004 | 09:23 PM
powerslider's Avatar
Check the throttle cable adjustment, if it's loose the ETC will kill the motor on decel.......
Old Apr 12, 2004 | 09:33 PM
BoatGuy's Avatar
Powerslider and pred19,
If it was the throttle, would it happen at all speeds? It only happens when I am on it really hard. Basically wide open throttle(WOT) through the gears quickly. When I am a little easier on it, such as trail riding the bike is absolutely fine. I have thought however, that it has idled low since new out of the box(just never adjusted anything).
Old Apr 12, 2004 | 09:46 PM
  #15
Well if your cable adjustment is boarderline it may very well act like yours does, you can simply unplug the connector to the throttle housing and try a few runs that way. If it quits stalling then it's the etc, you want an 1/8th" or so freeplay, if it's much more than that the cable adjuster is under the black tubing on the cable between the throttle housing and the steering stem. You can adjust it there, also if you think it idles to slow adjust the idle up.
Old Apr 12, 2004 | 10:24 PM
  #16
BoatGuy's Avatar
What would the backfire be caused from with this problem?
Old Apr 12, 2004 | 10:33 PM
  #17
The ETC cuts voltage to fire the plug, the fuel doesn't burn in the cylinder but does in the exhaust, backfire!!!!
Old Apr 12, 2004 | 10:38 PM
  #18
Hozed's Avatar
Originally posted by: trailrider500
Originally posted by: shackattack
Buy a yfz.
I would rather have my engine stall, then have frames crack,a arms etc break! I rather have my engine stall then have it blow up its been on the forums!
Why take a 50cc loss? thats like trading a big block for a small block[img]i/expressions/face-icon-small-confused.gif[/img]
lol... i aint gonna start anything but i am gonna speak... ive only seen and heard of 1 yfz frame crack... my pred frame and a ton of others have broke...
and there have only been a few cases of yfz's blowing up... but many pred trannys that have gone...
either way.. both great quads... just my pred seemed to have more problems than anyone elses.... maybe i got the one that was made on a friday afternoon by the new guy...
Old Apr 12, 2004 | 10:57 PM
  #19
trailrider500's Avatar
Originally posted by: shackattackBuy a yfz.
I would rather have my engine stall, then have frames crack,a arms etc break! I rather have my engine stall then have it blow up its been on the forums!Why take a 50cc loss? thats like trading a big block for a small block[img]i/expressions/face-icon-small-confused.gif[/img]
lol... i aint gonna start anything but i am gonna speak... ive only seen and heard of 1 yfz frame crack... my pred frame and a ton of others have broke...and there have only been a few cases of yfz's blowing up... but many pred trannys that have gone...either way.. both great quads... just my pred seemed to have more problems than anyone elses.... maybe i got the one that was made on a friday afternoon by the new guy...
LMAO!
I knew you would say something about that, thats why i said that in the first place to see what your reaction would be...
All in fun bro[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 12, 2004 | 10:59 PM
  #20
Hozed's Avatar
lol.. your lucky i was calm... if you saw what i looked like when i read it you would have seen steam coming out of my ears and a deathly glow in my eyes...
