Putting 400 scram back together
Should I use loctite on the flywheel nut and cover bolts and how did you torque the jug to spec ? There is no way to get a torque wrench on the nuts. Just enough room for a open end wrench. Is there a way to do this without a special tool ?
Thanks
Bob
Thanks
Bob
I didn't use locktite on the flywheel and have had it off and on several times with no problems of the nut backing off. If you do use locktite make sure to use the blue threadlocker. You can get a crows foot on the jug base bolts though the torque won't be exact with it, I think you can reach a couple of them with a torrque wrench and extension directly if I remember right, use those to get a feel of how much the torque is and then torque the others. Remember to retorque after initial warmup. Don't need any locktite on the flywheel cover bolts.
