trail blazer prob.
Old Apr 20, 2004 | 08:07 PM
daatv's Avatar
Default trail blazer prob.
weak spark changed cdi unit +coil +stater used cdi but still the same ran fine be for i rebuilt it could the be a ground that im missing the black and yellow wire that comes from the cdi unit to the coil is grounded is that normal[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 20, 2004 | 09:20 PM
Bubba297's Avatar
Unless you actually removed electrical parts when rebuilding and you have a spark, then I would say it's not the problem. Being around 2-cycles for years including chainsaws,weedeaters,etc. I have learned that usually a spark is good enough. Most of the time you have it or you dont. Have you taken a compression reading or double checked to make sure everything else is fine?
Old Apr 20, 2004 | 09:30 PM
daatv's Avatar
good compression the spark is so week that you allmost cant even see it
Old Apr 20, 2004 | 09:41 PM
Bubba297's Avatar
Open the gap on a plug to about .040 and see if it can jump it. If it can, then spark shouldnt be the problem.
Old Apr 20, 2004 | 09:44 PM
daatv's Avatar
ill try that one miun.
Old Apr 20, 2004 | 09:49 PM
daatv's Avatar
i just tryed that it will not jump theres only one wire going to the coil its black with yellow strip off the cdi unit when i put a test ltght to it from a positive it shows that its grounded it does not make any sense
Old Apr 20, 2004 | 11:18 PM
Bubba297's Avatar
What year is the ATV? If it's close enough, I'll grab the electrical schematic and see what we can find.
Old Apr 20, 2004 | 11:47 PM
conky's Avatar
I had a similer problem with my TB it turned out to be the wire that goes to the kill switch (the red switch by the head light switch ) was just dirty were it conected . The wire is under the front hood were the light is . Hope this helps.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
