oo tb bogging out at half throtle
Old Apr 22, 2004 | 12:39 AM
trailblazermudrunner's Avatar
Default oo tb bogging out at half throtle
my oo trail blazer is bogging out in half throtle i need help to figer it out
Old Apr 22, 2004 | 01:11 AM
MnFriesen's Avatar
do you have any mods done to it...and its a 250 right...with the way polairs changed the 400's name so many times it gets kinda confusing at times
Old Apr 22, 2004 | 10:38 AM
it is a 250 and it is stock
Old Apr 22, 2004 | 02:42 PM
dodgepower's Avatar
Couple things might try is make sure the carb is cleaned out and also check the plug bro.....Two strokes are terribly fenicky about that stuff....
Old Apr 22, 2004 | 03:12 PM
scramblered's Avatar
maybe a too lean jetting with the needle,raise the clip one notch then go try it again or be sure air filter is breathing cleanly.
you can see for a slide adjustments too with the throttle cable
for dysfunction.
also,a too soft secondary setting spring will bog the engine down when it
get at peak power.
Old Apr 22, 2004 | 04:17 PM
well i think i should have it servesed next month and ill let u guys know how it is acting thanks for the info
oh ya how would u tighten up the chain
Old Apr 22, 2004 | 05:18 PM
RedEX's Avatar
The choke isn't sticking is it?
Old Apr 22, 2004 | 05:26 PM
no it dosent seem to be sticking but once i get passed half throtle it flys[img]i/expressions/face-icon-small-confused.gif[/img]
Beeline08
Nov 11, 2016 04:00 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
tysonbully
Sep 28, 2015 02:30 AM
Halffast17
Sep 11, 2015 02:30 PM
