clutch buttons
Old Apr 23, 2004 | 10:15 PM
thewayout420's Avatar
Default clutch buttons
hey guys,i replaced my clutch buttons a few weeks ago and tonight i took my secondary apart and the button are already busted.is there something wrong?i bought the hpd button kit but they wont sit down into place,unless they need to be hit with a hammer to get them set?
Old Apr 23, 2004 | 10:23 PM
ftwflh's Avatar
THe bolt holes could be striped a little not letting them stay tight.Get you a cheap secondary off of ebay and try it.
Old Apr 23, 2004 | 10:25 PM
they tighten down pretty tight so i dont think the threads are striped..
Old Apr 23, 2004 | 11:30 PM
Bubba297's Avatar
If they are like the originals, they can only go in one way. I havent personally seen the HPD super duty button kit. I know on their roller kit you have to machine the bolt holes through and grind on the bcak side of the clutch sheave. Is that the way those work?
Old Apr 23, 2004 | 11:35 PM
yeah the directions said to grind down the back piece and drill the hole so the bolt will go through.the hpd buttons wont sit down into the slot in the moveable sheave,im pretty sure i either got defects or the wrong buttons..
Old Apr 23, 2004 | 11:46 PM
Bubba297's Avatar
Are you sure they cant go in backwards? You cant put a stock button in wrong. Other than that can you lightly tap them into place? When I drilled my holes, the roller helix was a snug fit for sure.
Old Apr 23, 2004 | 11:55 PM
they wont go in either way i try,i realize its rounded a certain way but the corners of the buttons arent rounded off and i think thats what is stopping them from sitting into place..
Old Apr 24, 2004 | 01:10 AM
radblazer400's Avatar
I had to modify mine just a bit when I put them in. File or sand the outer radius until the buttons drop down in like the stock ones.
Old Apr 24, 2004 | 02:21 AM
fishslab's Avatar
If your busting buttons quickly, that's a good sign you need a new secondary spring as well.
Old Apr 24, 2004 | 10:26 AM
i just put a hpd aggressive clutch kit in the same time i installed the buttons,hey radblazer how much did you have to file?
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
