Thinking about racing my predator
Oh yeah, and another thing.. what would i do to the suspension? i mean, im pretty comfortable with it now, even though its a little tuff to corner at high speeds.. but.. should i just screw with it till i find a setting i like?
If your suspension keeps you too high in the travel in the corners you'll never be able to corner as quickly as your competition because of the tippy feeling it results. If your initial suspension action is too stiff it will beat you to death and tire you out quickly. And if your dampening is not progressive enough you'll blow through the travel and bottom out on big hits. I guess the point I'm making is you can certainly work on getting the stock setup as good as possible, but the guys that take the time to learn and properly setup thier suspension while BLOW by you on anything other than a perfectly flat straight away, and lets face it, in MX theres hardly ever a perfectly groomed surface all day..... [img]i/expressions/face-icon-small-wink.gif[/img]
