ok this is odd for my 400 2x4
Originally posted by: duneaholic
Thanks for the NAPA belt info BBS. Cool to know.
If you have "power braked "it you have messed up your belt.NEVER do that with a Polaris.If you want more engagement go with a differant primary spring and/or shift weights.But with the kit RcR told you to use it should be close to on the money.
More than likely the belt is shot. Even when drag racing, only enough stall to make the belt just touch the sheave is all you should do. Any more than that means you are cooking the belt and wearing out the clutch at the engagement point.Bubba
