Belt life vs. Clutch kit
I have found that the installation of a Clutch Kit will indeed reduce wear, but it will tend to strecth the belt more causing belt slap.
I have 2 Polaris belts with about the same amount of time on them, one was used with bone stock clutching , the other with a HPD aggressive Kit. The one run with the stock clutches measures about .045 narrower, than the one run with the kit. The one used with the kit still measures within Polaris spec but it slaps quite badly, and is noticably longer.
Just thought some of you might like to know.
See Ya, Drew
See Ya, Drew
There are other variables that effect belt life, such as riding style and clutch alignment.
I curently use the Goodyear PowerStreak belt. I've had it on for about 4 months now and it shows no signs of wear. It seems to made of a superior rubber compound, compared to the OEM belt. Considering we charge $42 for a Polaris OEM belt (not by my choice!) why would'nt you move up and try the Goodyear for the same price?
Steeldon
09-09-2015 09:38 AM
Elkaholic
09-06-2015 02:44 PM
