I need a little more help tightening the chain on my 325 Trail Boss
Old Jun 11, 2004 | 06:09 PM
insane325Boss's Avatar
Default I need a little more help tightening the chain on my 325 Trail Boss
I got the bolts loosened on the axle under the hitch and on the brake caliper but i cant figure out the next part, where you have to put a screw driver in the sproket. I looked but i couldnt figure it out at all im completely stumped.
Old Jun 11, 2004 | 06:15 PM
scrambler123's Avatar
there is a hole in the sprocket you put the screwdriver in there and roll the bike until the screwdriver slides in to the hub.
Old Jun 11, 2004 | 06:38 PM
doug1973's Avatar
turn the axle housing with a pipe wrench. ( after the bolts are lose.)
Old Jun 11, 2004 | 06:41 PM
doug1973's Avatar
i have a 2000 325 trail boss . what year is yours??
Old Jun 11, 2004 | 09:53 PM
Mine is a 2002. I dont get what you guys are saying the only hole i have in my sprocket are the big gaps in it.
Old Jun 11, 2004 | 09:56 PM
Where is the axle housing???
Old Jun 12, 2004 | 09:17 AM
doug1973's Avatar
this should help. go here
Old Jun 12, 2004 | 09:18 AM
doug1973's Avatar
oooooooooopppppppppppppppssssssssssssssssssssssss
Old Jun 12, 2004 | 09:21 AM
doug1973's Avatar
http://216.37.204.206/wps/Polaris_OE...=13&A=268&B=32 or use
http://216.37.204.206/wps/Polaris_OEM/PolarisATV.asp
copy and past this address it shows pics.
Old Jun 12, 2004 | 10:53 AM
scootergptx's Avatar
Supersock
Hired Gun!
A wrench on the axle is the easiest way. Once you do it, you won't believe how easy it is. Trust me, we've all been there, once. Try rolling it forward, sometimes that loosens the axle and will tighten the chain.
