compression help
Old Jun 17, 2004 | 06:19 PM
troubledintoledo's Avatar
Default compression help
i'm in need of some help getting my compression up on my trailblazer its giving 50-60 recommended is 115,can the ring on the piston be interfering or causing the problem?
Old Jun 17, 2004 | 06:41 PM
CED's Avatar
CED
Yes sir,sounds like you need to freshen up your top end.
Old Jun 17, 2004 | 07:11 PM
i've replaced piston and rings could the rings being out of place or damaged make the compression drop or the tb not start?thanks
Old Jun 17, 2004 | 07:15 PM
CED's Avatar
CED
Well if your compression is under 100 the bike will not start.Double check everything that you did.
Old Jun 17, 2004 | 08:58 PM
funk's Avatar
There are a few things you need to consider. If the piston has more then two rings the opening on the rings need to be opposit of each other also the valve timing needs to be correct one tooth of and your compression is sliding by the valve. make sure the parts you put in are right for the machine if it has been bored out you need the correct piston and rings for the bore. Hope this helps
Old Jun 17, 2004 | 09:03 PM
ftwflh's Avatar
When you replaced your piston did you bore the cylinder and put in a new oversized piston?
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
