Scrambler chain questions
Old Jun 22, 2004 | 04:40 PM
crpadiem1's Avatar
Default Scrambler chain questions
First off is the stock chain on my 2003 500 4x4 Scrambler an o-ring or non o-ring chain. Second which lube should I get and since I got it used what should I do to get it clean and start taking care of it. When I bought it the chain was coated with grease and dirt, I sprayed it off as good as I could and use a cheaper lube I got from Dennis Kirk. I've found though that if I ride for more than an hour or so hard, then it starts making a chain noise when pulling up a hill. Give it a coating with the lube and the noise stops. I don't think I should have to go to a dealer to get the lube, just want something I can get locally as I don't mind the maintenance, just want to know the general way to clean up and maintain the chain that works for trail riding, I'm not a racer and don't run to the mud but I do go through mud and water at times. I keep hearing of this maxima chain wax, should I use this. Thanks for the help guys.
Old Jun 22, 2004 | 04:46 PM
BUBASCRAMBLER's Avatar
Yes it is an O-ring chain
Use polaris chain lube (or any O-ring safe chain lube)
As for the noise, check the plastic chain guide on the bottom (part # 20 at the followimg)
http://www.partsland.com/index.cgi?N...SHOCK-MOUNTING
This may need adjusting so it is not constantly rubbing with presure.
I personally have not heard of or use the maxama chain wax/lube ?????
Old Jun 22, 2004 | 04:48 PM
BigBadScrambler's Avatar
To clean it, I bought a Uneek Chain Scrubber from Rocky MT. It works great! And for a lube, I use Tri-Flow. With the Tri-flow, it seems nothing will stick to the chain.
Old Jun 22, 2004 | 04:58 PM
tbsleeper's Avatar
check the chain u might be missing some of the o-rings
Old Jun 22, 2004 | 05:35 PM
scootergptx's Avatar
Supersock
Hired Gun!
Dennis Kirk had some O-ring chains clearanced on his website. Got a Regina gold for 31 dollars.
Old Jun 22, 2004 | 11:05 PM
scramblerXrated's Avatar
i use P.J.1. black label chain lube.
X
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
DeFox500
Jul 26, 2015 06:32 PM
95wolv
Jul 17, 2015 08:13 PM
maxjung
Jul 15, 2015 11:59 PM
