gearing
Old Jul 18, 2004 | 05:45 PM
thewayout420's Avatar
Default gearing
im just wondering what gearing i should run with my new engine mods?stock was 13-34,i switched to a 38 tooth sprocket..im sure the new mods will give me good bottom end so should i run a 12-34 setup for more topend?and if i do,will i still have good bottom end?thanks for any help..
Old Jul 18, 2004 | 06:27 PM
tbsleeper's Avatar
Default gearing
i would say just go 13/34 or 12/34 like u said
Old Jul 18, 2004 | 07:04 PM
EAB's Avatar
EAB
Default gearing
12-34 will give you more bottom end and less top speed.
Old Jul 18, 2004 | 07:08 PM
tbsleeper's Avatar
Default gearing
wait if u go down in the back that gives u more on top..right? and go higher in the back that give u less on top right???
Old Jul 18, 2004 | 07:21 PM
EAB's Avatar
EAB
Default gearing
Check out trailrider500's pic page. He has a gearing chart with top speeds for the Pred. The actual speeds dont really matter, but you can see the change that each gear makes.
Old Jul 19, 2004 | 12:26 AM
scrambler123's Avatar
Default gearing
higher on the front is more top speed. lower on the back is more top speed.
i use 13/36 on mine and it seems to work well.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
