RCR STAGE 1 Accelaration
Old Jul 23, 2004 | 09:54 PM
tbsleeper's Avatar
Default RCR STAGE 1 Accelaration
if a trailblazer is tuned near perfect it will run unbelievable...i no mine is near perfect on top and a lil lean on the bottom and a lil rich in the mid. mine gets stronger as it gets hotter on bottom, the mid loses a lil but on top its always running good.
and 1.5 turns out is the stock for the airscrew and the farther out th ehotter it will run
Old Jul 23, 2004 | 10:00 PM
tbscrammy500's Avatar
ok i just need to know exacly where this air screw is located on the carb and what it looks like. I just dont want to adjust the wrong thing. TBsleeper, how did you get your trailblazer tuned like that?
scrambler123's Avatar
mine ran strong at all throttle postitions and at all temperatures when it was stock and modded.
Old Jul 23, 2004 | 10:05 PM
tbsleeper's Avatar
jsut kept playing with teh jetting and still am!!! gotta fix that low end and i almost got it fixed and the mid im not the worried bout cuz i rather it run rich there cuz i ride alot in mid
Old Jul 23, 2004 | 10:07 PM
  #15
by low end do you mean at idle so you need a different pilot or is it the needle?
Old Jul 23, 2004 | 10:08 PM
  #16
yeah im going to see if that air screw was my problem, and if not, i dont know what im going to do
Old Jul 23, 2004 | 10:10 PM
  #17
tbsleeper's Avatar
i did change the pilot to a 30 and i lost te stock one so idk wat it was stock
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Huntingdeer
Aug 23, 2015 12:06 AM
